nt1953
- Sep 4, 2004
- Huntsville, Alabama
I want to replace the motor bearings on the Taiwanese clone (Bridgeport) that I am doing some refurbishment on, but I cannot figure out how to remove the fixed part of the pulley and the motor shaft adapter.
The motor appears to have a sleeve on the shaft that increases its diameter and provides the surface and diameter required for the movable part of the pulley. I assume the fixed pulley is a press fit to the shaft adapter, and they may both be a press fit to the motor shaft.
There is no visible keyway or set screw, but there is some sort of pin in the adapter (shown in one of the pictures) that is not centered in the hole it may or may not have been inserted through. The pin does not appear to be in far enough to allow the shaft adapter to clear the pin if you attempt to pull the adapter off of the end of the shaft.
I applied some moderate force in an attempt to pull the shaft adapter/fixed half of the pulley off of the motor shaft, but nothing moved and I do not want to warp or break anything.
I am considering drilling a hole into the pin to see if I can pull it out, but I would have to machine out the hole to make the hole and pin align.
The motor is s Jin Shin 3HP.
Does anyone out there have any experience with removing these parts from a motor like this?
![IMG_20220109_133612[1].jpg IMG_20220109_133612[1].jpg](https://www.practicalmachinist.com/forum/data/attachments/281/281878-aca6eb9e50d7731934ba9a4c692ecba8.jpg)
![IMG_20220109_133536[1].jpg IMG_20220109_133536[1].jpg](https://www.practicalmachinist.com/forum/data/attachments/281/281876-51634c36c887f699b73d85f818cd6f7e.jpg)
![IMG_20220109_133558[1].jpg IMG_20220109_133558[1].jpg](https://www.practicalmachinist.com/forum/data/attachments/281/281877-a12c6668d0e16a05cb16d88974cfbcfb.jpg)
