Help with Lagun FTV-2 and Dynapath Delta 40
Camaro291
Apr 19, 2022
Hello. I’m trying to get a Lagun FTV-2 up and running. It is currently dead. I don’t have any paperwork for it. It has the Delta 40 control, a Siemens Simoreg Motor control package and a Sysmac c28k motion controller. I’m in need of schematics to troubleshoot. I’ve reached out to Wesel (CNC retrofit mfg), Lagun and Dynapath but no luck. Any thoughts? Any help?
The control only takes 110 or 220 VAC to run. It has a standard connection on the power supply. That will not help with anything else but you could see if the cnc powers up with everything else off. If the monitor does not work a standard VGA monitor can be used in its place. Based on the date of this post I hope your well past this by now.
