Thanks mate,I appreciate your comments. the more i think about it, the less it will probably suit me. I was concerned about the size, the only thing i was thinking of is the price, which is very cheap. I would really probably prefer a smaller lathe, maybe 300x900, but as you know they are hard to find secondhand. Do you have any preferred places to buy machines you could recommend? I am in the north west, but can travel all over tassie if necessary.
There's nowhere in Tasmania that has used machinery available on a commercial basis. You have to be lucky with Gumtree or similar, or import from the big island - which is what I do. Bought a lot off of eBay and had the things freighted home.
Also depends on your budget - if it's small, getting stuff from the big island is out as freight is going to add $500 to $2000 to anything you buy, depending on size & location, ease of access etc.
There are a couple reasons why that machine is cheap and they probably aren't real good ones. Wear is the first & obvious one, which can be checked for. The other is size/weight.
It's a truism that you can use a big lathe for small work but what people don't say is, it's a PITA. You'll need an engine hoist, gantry or similar just to change out the big chucks. Or grip a small chuck in the big 4 jaw, but this limits your safe top speed to what the big chuck is rated for. Etc etc etc. I'd rather use my Chipmaster than my Monarch that's for sure.
Frankly if you have the money buying a new H&F AL960B made in Taiwan is your best bet. They're reasonable to good lathes. The AL1000G is a better machine but a lot more dollars. Or hang out for a decent UK or USA machine, they do come along.
I personally wouldn't buy a Hercus as they're just knockoff copies of a South Bend, with all the flimsy, flexible and feeble limitations of one. But then I've been there, done that and learnt what doesn't work for me. YMMV.
PDW
