richard newman
- Jul 28, 2006
- rochester, ny
ratchet?
Νο the center rod is hardened steel.Ι wote "rutchet"..keyboard mistake..I means "ratchet"so the same mechanism,is in the toolpost,in order to turn on the toolpost and after that,close and it tightens the toolpost.Its simular idea.Is the center rod soft? If so, it could be drilled out and later replaced. Perhaps it is pressed in, or had the compound shrunk onto the rod, by cooling the rod and heating the compound until the rod slipos into the compound by hand. When the parts are at the same temperature, the rod is firmly clamped into the compound.
Not sure what a "ruchet,chesnut" is. A photo is the quickest way to find the English names.
It is clearly shown in the photo in post #35, you have to click the picture a few times to get it to magnify enough to see down in the hole.Not sure what a "ruchet,chesnut" is. A photo is the quickest way to find the English names.[/SIZE]
When I look at the two photos in posting #15, a thought arises: In the left photos (ι.jpg), we see four threaded holes on a common circle. In the right photo (τ.jpg), also with four holes on a common circle, one pair being threaded and the other looking like solid hard round pins. It looks like these two circles are the same diameter, so one could rotate one with respect to the other, so the holes line up. The upper holes look large enough to admit an Allen key to unscrew a buried socket head screw.Some more fotos from todays not progress work at toolholder problem..
Thats the first thing ,I am thought about,that the 4 holes to the top and the 4 holes of the bottom,is the same thing,but its not.The truth is,the top holes,hold the circle,in order to push the toolpost lock lever to position.Allen screws.The bottom blind solids,I dont have any idea,for what the beer,doing there.There not hold nothing,everything,in that part,movit everywhere it want to be.I ts like four pins,putting there for some type of holders,or stop,but what?When I look at the two photos in posting #15, a thought arises: In the left photos (ι.jpg), we see four threaded holes on a common circle. In the right photo (τ.jpg), also with four holes on a common circle, one pair being threaded and the other looking like solid hard round pins. It looks like these two circles are the same diameter, so one could rotate one with respect to the other, so the holes line up. The upper holes look large enough to admit an Allen key to unscrew a buried socket head screw.
In a serius rebuild,ALL THE PARTS MUST BE CHECKED for cracs,missing parts,unworking parts,to do a right cleanig and oiling,inspection of the oilers,bearings replace and a lot of the things,that only a real machiner wants to do.The way to treat your tools,show your character.If something looks fine,it doesnt mean,that it is fine.And I ask you.Why the toolpost dont remove?What is that who stop it from separated,as well?Is it fit and stay in position,on the job?Or its brake on a heavy turning and do some serius damage to the lathe,or in a worst case an accident?food for thought.Another question is WHY remove it it is being such a problem? If I understand correctly it all moves nice and free so why not just work with it as is?
Hmm. Do you know anyone who can X-ray that assembly?Thats the first thing ,I am thought about,that the 4 holes to the top and the 4 holes of the bottom,is the same thing,but its not.The truth is,the top holes,hold the circle,in order to push the toolpost lock lever to position.Allen screws.The bottom blind solids,I dont have any idea,for what the beer,doing there.There not hold nothing,everything,in that part,movit everywhere it want to be.I ts like four pins,putting there for some type of holders,or stop,but what?
Yeah, I mentioned that 3 days ago, on sunday. It is a critical consideration. Once cleaned it should become clear under magnification whether there is a thread (and the direction), knurls, or evidence of pressing. As mentioned, is it pressed or threaded in from the bottom, like a wheel stud.To much crap around center post to tell if it is threaded or just pressed into slide.
As suggested by Rob F in post 44, I magnified the picture in post 35, and looked deeper. It does seem that the upper four holes are aligned with the lower four holes.
I also see what could be a kind of nut with radial features surrounding the big stud in the center. Could this be....Its already unscrewd.But nothing moves.
I dont have nothing of numbers or dimensions.The mother company,have also nothing..Yeah, I mentioned that 3 days ago, on sunday. It is a critical consideration. Once cleaned it should become clear under magnification whether there is a thread (and the direction), knurls, or evidence of pressing. As mentioned, is it pressed or threaded in from the bottom, like a wheel stud.
The other way to work this problem is to ask how you would retain that threaded stud. But any serious analysis needs the basic dimensions to understand the constraints.
Notice
