jscpm
- May 4, 2010
- Cambridge, MA
Put a tight fitting wooden dowel into the pipe before drilling it.
Drill from the outside only.
If you're getting burrs that you can't bend with pliers you probably need to sharpen your drill. What speed are you running the drill? If you're going way too fast you will be dulling even a new one almost instantly. If you took 25 minutes to do one hole, something is very very wrong. Drilling that hole should take no more than a minute.
I have been trying to figure out how to drill holes through round 1" ERW (11 gauge). Each time I drill, the hole that comes out the far
side of the tube has 'ridges' (I'm not sure of the term) when the bit exits. I've included some photos of the exit hole.
I am using a drill press. I apply a good amount of drilling coolant/oil and clean off the drilling shavings every 15 or 20 seconds of drilling.
I tried to delete the last photo (on the right). That is the inside of the entrance hole and it didn't get 'cleaned' out. I'll save that issue for later...if I can figure out the exit hole problem.
Would you have any suggestions on how can improve this so the outside of the exit hole is smooth?
Thanks.
X2 on that, my first thought was a blunt drill being run too fast.
Uh dumb question along with stating what should be obvious. But with all the previous posts that pretty much covered your issues and possible solutions. Then if you go to the trouble of taking and posting a YT video, why not just do a search there about drilled hole deburring? Between the two sources you'd have just about anything you could want.
Recently, I've been at 220rpm and getting the burr. I did notice that the center drill bit and the 1/4" bit went through the tube smoother at 830rpm though.
Notice
