They are a great tool, IF you take the time to learn the setups.
You can get the manual, and a video, from Hossfeld.
http://www.hossfeldbender.com/
You need to keep an eye on all the small parts- they are mostly heat treated, and not cheap from Hossfeld. So even though it looks like you could just use a piece of 3/4" hot rolled, it wont work anywhere near as well as the original parts.
I use one almost daily, for the last 25 years, for semi-production bending.
I have trained a slew of guys over the years to use it- If you have a copy of the manual handy, to refer to for intial setups, you can get good bends out of it pretty quickly.
I keep threatening to write a book about bending with one, but it may be a while till I get around to it.
But I would be happy to answer any questions you have about using it.
A few tricks that arent in the book- I do an enormous amount of bending on top of the bender- I ordered special extra long 3/4" pins from Hossfeld for the fixed and swinging arms for a few bucks, and you can freehand bend up to 5/8" or so into all kinds of intricate shapes, straighten stuff, and so on.
I also bend circles and arcs all the time with the angle iron flange Out dies, which have fixed dies in inch or two increments from 3" up to 36" radius.
This means you can pull a perfect circle from something like 1/2" round, 18" in diameter, again and again. Very handy, we make circles all the time this way.
I also have a set of pieces of pipe, ranging from 1" up to about 6", in 3" long pieces, that I use as mandrels for bending smaller circles on top.
You bend a coil spring like shape, up to about 3/8" hot rolled, as long as you want, then slice em up on the bandsaw.
Check my website- virtually everything I make is hossfeld bent.
