DubbleTrubble
- Feb 8, 2021
- Hollyweird CA
I've been working through a Haas HRT9 that I picked up at auction a few months back. It is tripping a "Hi Curr" error on the controller. I've covered much of the process in another thread here on PM - https://www.practicalmachinist.com/forum/threads/should-it-spin-by-hand-hrt-servo.403540/ Because this isn't a Haas specific issue and I haven't gotten a response in the other thread to this specific issue, I'm hoping the bigger audience might be able to help me.
I found a nice replacement servo on eBay with the same 3528 motor and F windings. It was the only one I could find after looking around for a week. The replacement motor has a tach, which I need to remove and I only have one chance to get it right. When I say tach, I mean the type with its own commutator and windings riding on the motor shaft.
As you'll see in the pictures below, the tach rides on a 5/8 OD hollow shaft that surrounds the 1/2" motor shaft. I can't quite get visual access to the end of the 5/8'' portion because it is hidden by the brush holder, which cannot be removed without removing the tach (I think).
My first thought is to use a gear puller to pull the tachometer and 5/8" shaft off the motor shaft. Before just going for it, could someone confirm whether this would be the best way to go at it or should I try something else? Should I use any heat? Should I try to remove any of the blue epoxy towards the bottom of the 5/8" section?
I appreciate any help offered.
