kustomizer
- Aug 17, 2007
- North Fork Idaho
.22 blanks so you can hear it when you blow a tail light fuseWhat caliber fuse do you use in the truck?
Fuse.... Hmm... Isn't that the thing we used to use to wrap the aluminum foil around to get the radio to work?What caliber fuse do you use in the truck?
Fuse? We don't need no stinkin' fuses!What caliber fuse do you use in the truck?
All you gotta do is push the green button.....I am a 19 year old apprentice who works in quality assurance. Within my factory, we have CNC Mills and Lathes, mainly mazak and haas. The work that machinists do looks so intimidating, and makes me wonder how easy it actually is to program or operate these machines. People I ask say it’s easy work, and that it is just button pushing, but it looks so much more harder than that.
Bare in mind, I have 0 experience on machines, apart from a couple weeks on manual lathes and mills.
Thanks
RPM = 4 x CS / DIA, feed rate = IPT x # flutes x RPM are both examples of algebra.Algebra ? I can't remember ever using algebra, thank god. Double yes on the trig but what did you use algebra for ?
Nah, that's just arithmetic. Algebra is where you get those nasty variables and equations and all that stuff.RPM = 4 x CS / DIA, feed rate = IPT x # flutes x RPM are both examples of algebra.
Chances are you see one type of work they do and they say "it's just a push of a button" about some other type of work. For example, you see the setup programmer at work setting up the machine to process some new part, and he tells you about working on the CNC machine from the operator's point of view.People I ask say it’s easy work, and that it is just button pushing, but it looks so much more harder than that.
I've been doing some moldmaking recently, and that's an area where a little mistake can have a pretty high cost. If you're running a batch of production parts and you make a mistake, ok, fix the mistake and make another part. In a mold, oops, throw it away and start over. You could lose days of work.I learned in trade school that not everyone is cut out for it. In fact, most aren't. It was only a one year class, and out of 21 people, 11 finished, and only 3 of us had high aptitude. We were handed jobs upon finishing the program. I went to work as a prototype machinist which was quite fortunate.
Manual machining and cnc programming requires a high aptitude for the work. It's got to be in your blood. My grandfather was an airplane mechanic. My father was a car mechanic. My uncle owns an HVAC company. Practically every man in my extended family does something mechanical. Also, a lot of people are simply too absent minded not to make mistakes all the time. You've got to have a talent for not making mistakes very often, or when you do, not making them twice. Alot of mistakes are practically inconsequential. You can make these. Some mistakes are catastrophic. These you cannot.
a pair of dykes is always best..They kept the exhaust on my first car from dragging the road for years. And when they'd break I'd just go grab another hangar and a pair of dykes.
yeah math has very little to do with modern machining, especially CNC. more of just understanding how the cutter removes material, how the machine moves and how to translate that into CAM/code. i'm about average with math, and sure, i use it - but its super basic stuff.I suck at math. I mean SUCK at it. But my shop is currently booked in to 2024 with REALLY good work. So I have to disagree with you on that point. CAD and CAM to the rescue. It all depends on the type of work the shop does.
I agree on all other points.
Except when you put stock in the toolholder of your mill and put a bank of gang tools on the table...Would believe most on here might agree that sometimes, yeah- sometimes,..a traditional machining method gets tossed right out of the window particularly with older equipment and some material that's "supposed" to be the same material as the last time you ran it well.
After having run Screw Machines for over 25 yrs I found CNC machining quite a challenge in the programming end of it, and was kinda' lost without cams and a set of feed gears .
The fundamental differences I found after a few years between a Mill and a Lathe was -
*A mill moves the material to the tooling..
*A lathe moves the tooling to the material, dont let it overwhelm you.
If you can build yourself a basic machining foundation of knowledge, LISTEN to what the knowledgeable guys in the shop submit to you , eyes, ears wide open.
There is a huge difference between a CNC operator and a machinist I can train a seal to operate a CNC machine with a few fish and 10 minutes of my time depending on the part he will be running. A skilled machinist takes years to master in fact it is a never ending learning cycle but to be some what proficient I would say 5 years minimum. Math is not so important we have computers for the CAD/CAM I have not done any manual math for 25 years other than adding and subtracting on a calculator. A lot of shops have different people to program and setup then they have people to push buttons and run the parts the difference between those 2 jobs is night and day.I am a 19 year old apprentice who works in quality assurance. Within my factory, we have CNC Mills and Lathes, mainly mazak and haas. The work that machinists do looks so intimidating, and makes me wonder how easy it actually is to program or operate these machines. People I ask say it’s easy work, and that it is just button pushing, but it looks so much more harder than that.
Thanks
We make a lot of things in pairs, one of our biggest all time problems is operators with no math skills that would make 125 lefts and 75 rights, swear up and down that they made 100 pairs. There was a calculator at every machine yet we had the problem almost daily. I spent most of 30 years trying to teach 3rd grade math to adults.yeah math has very little to do with modern machining, especially CNC. more of just understanding how the cutter removes material, how the machine moves and how to translate that into CAM/code. i'm about average with math, and sure, i use it - but its super basic stuff.
if someone cant count simple quantities, i'm not sure they belong in any trade, lolWe make a lot of things in pairs, one of our biggest all time problems is operators with no math skills that would make 125 lefts and 75 rights, swear up and down that they made 100 pairs. There was a calculator at every machine yet we had the problem almost daily. I spent most of 30 years trying to teach 3rd grade math to adults.
Notice
