metalchipmaker
- Jun 2, 2022
Hello, I just wanted to verify clamping method on thin aluminum sheet.
Most of the times, I deal with aluminum or brass bar that are usually clamped with vise.
There is one component that I need to machine out of aluminum sheet that is too thin (0.063" x 5.5" x 14") to clamp with vise.
Looks like most of times, these parts are machined with laser cutter or CNC router.
I've been outsourcing these to be cut on laser cutter, but I wanted to see if I can just make them in-house with a CNC mill to save some outsourcing cost.
I've saw YouTube videos with a vacuum chuck, but other components that are already set-up for vise system do not justify getting a vacuum chuck.
I also saw the superglue method, but I don't know if I trust the rigidity of the set-up when 45% of the material is removed from the aluminum sheet.
I was going to just make an aluminum subplate (1" x 6" x 15") that will clamp the sheet with 6x toe clamp.
Is this the most painless way to get this part machined or am I overlooking something obvious?
