Does anyone have a good method for measuring or gauging the size of small chamfers/edge breaks on the entry to small holes? Hole in question is 0.09375" (3/32" or 2.38mm) diameter, drilled blind hole. Chamfer needs to be kept small and it needs to be consistent across part runs to within about +/-0.002" on outer diameter as the chamfer's OD is the projected/pressurized area of a valve seat and the consistency of its opening characteristic is critical. We are still assessing the best deburring method for this hole too - unsure whether we'll use a standard 45deg chamfer or something else (eg a 60deg chamfer or a rounded corner) because being burr-free on the flat seating surface is critical but so is the pressurized area. Material is 7075.
Is this something that could be done best an optical measurement like a vision system? We don't have a CMM or vision system, just hand tools. We could make some go/no-go gauge pins for this perhaps, for visual assessment with a microscope. Are there other ways that might work better? There are other elements like this that we'll need to measure soon that are not circular, where gauge pins might not be an option as a result, so any suggestions would be super helpful.
