How to drill a large hole in steel without a mill
Strostkovy
Oct 29, 2017
Many welding shops rent out plasma cutters. We rented some during repairs of our equipment. Just make a small template washer and go pshhht.
GregSY
Jan 1, 2005
Houston
The big questions is...what kind of drill press only goes down to 540RPM???
Also, for what it's worth, a knee mill, aka, Bridgeport, is not the ideal tool for this job either.
David_M
Sep 30, 2014
Midway, GA, USA
If it has to be your drill press, you might consider an inline planetary gear reducer:
I have this for a job. It is used by ice fishermen to slow down their battery drills to use with large ice augers. Your 540 rpms would be reduced to 150 and the torque increased by 3.6 times.
Someone would need to modify the output shaft to take an annular cutter, hole saw or whatever. It would need a simple torque arm too. I would modify it in a way to make it as short as possible. You may still need a guide bushing clamped to the part being drilled to steady things.
Look for Clam power drive. You can get them for about 70 bucks.
Strostkovy
Oct 29, 2017
I've gotten too phreaking lazy- I'd just drag it down to the local waterjet place and they'd pop it out zip zip for very little $$. Probably the same with plasma or laser.
It used to be common for use to do "embiggening" jobs, where a part had an undersized hole that needed to be larger. It was so cheap and easy for us because I had a program for every common hole size and the plasma cutter had a taper and floating head. Just crash the plasma roughly into the hole, wiggle the plate until it dropped in, zero and start the cut.
metalmagpie
May 22, 2006
Seattle
Go to your local welding supply and rent a mag drill. You may have to buy the correct rotabroach bit but it will work enormously better than a hole saw. 1-1/4" is right in a mag drill's sweet spot. Here's a closeup of my little Steelmax (Poland) cutting a 2-1/16" hole right through a weld seam:
That is a curved surface, so I have a little "table" I tack onto the tank so the mag drill can attach to a flat surface.
metalmagpie
dstig
Aug 22, 2014
W WI
Just to throw another option out there... If this is on new stock, perhaps consider sending it out to either a local shop with a laser or plasma table or one of the newer prototype places like oshcut.com or sendcutsend.com on the web. It might be cheaper and easier to do that as your drill press seems a bit high on rpms to run a hole saw like you need. I have rented a mag drill on occasion too, but you need to supply the bits for the most part. Might be cheaper to send it out to be cut.
dian
Feb 22, 2010
ch
see, thats the point, the trailing cutter doesnt catch. carbide bits available also.
