tylersteez
- Jul 9, 2019
I was making a bronze bushing and on the final operations of parting off the excess material and facing it down to spec. while parting off the excess, The force of the part off tool overcame the chuck's clamping force on that narrow edge and the part popped out the chuck. Luckily zero damage to me or the machine but the part is damaged cosmetically. it should still work fine for its application luckily, just a non critical bronze bushing.
I've attached a basic drawing of the part, it is 5.5" in diameter with a 4" bore thru it. The raised ends are only 3/8" which doesn't give me a lot of material to bite onto with the chuck after I flip the part around and start to finish the other side. I should have just let the bandsaw cut the excess off and then took light cuts to face it off but tried to save time, however I know there's got to be a better way to chuck this part.
