Marankie
- Jun 11, 2010
- Newbury Park, CA
Hey all,
Recently bought a press brake with a Hurco AB7 back gauge and ram control. I am having trouble getting the Y axis (bend depth) manual jog to any further than .5" up or beyond the limit switch when in active mode, it just stops. No errors, basically just goes to 4.491 and stops, limit switch is at 4.00.
It manually goes further without a problem, it will also adjust all the way up with the Y axis in jog mode, the tooling I have on the press needs to be at about 2".
I've been through the manual multiple times, have tried calibrating but no results. Any help would be appreciated.
Thank you
Greg
Thank you
Greg
