Hurco BMC30 problems with SW2018
This is the post-processor g code:
N1 G00 G90 G17 G40 G80 G71
N2 (6MM X 60DEG HSS CENTERDRILL)
N3 X25.4 Y25.4 T06 M06
N4 G75 S500 M03
N5 G90 G54 G00 X8.327 Y-7.955
N6 Z3.
N7 G81 Z-1. F10. M08
N8 G00 Z25.
N9 X26.792 Y-26.792
N10 Z3.
N11 G81 Z-1. F10.
N12 G00 Z25.
N13 M09
N14 (5.0mm JOBBER DRILL)
N15 G90 T14 M06
N16 G75 S600 M03
N17 G90 G00 X8.327 Y-7.955
N18 Z3.
N19 G81 Z-12. F20. M08
N20 G00 Z25.
N21 X26.792 Y-26.792
N22 Z3.
N23 G81 Z-12. F20.
N24 G00 Z25.
N25 M09
N26 M05
N27 M02
This is the reworked g code that I use to run the machine:
N1 G00 G90 G40
N4 G75 S500 M03
N5 G90 G00 X8.327 Y-7.955
N6 Z3.
N7 G81 G01 Z-1. F10 M08
N8 G00 Z25.
N9 X26.792 Y-26.792
N10 Z3.
N11 G81 G01 Z-1. F10
N12 G00 Z25.
N13 M09
N15 G90 T14 M06
N16 G75 S600 M03
N18 Z3.
N19 G81 G01 Z-12. F20 M08
N20 G00 Z25.
N22 Z3.
N23 G81 G01 Z-12. F20
N24 G00 Z25.
N25 M09
N26 M05
N27 M02
E
N2 (12MM CRB 2FL 25 LOC)
N3 X25.4 Y25.4 T03 M06
N4 G75 S2000 M03
N5 G90 G54 G00 X13.539 Y10.764
N6 Z3.
N7 G01 Z-10. F400. M08
N8 G41 X17.951 Y6.351 F150.
N9 G03 X18.8 Y6. I18.8 J7.2
N10 G01 X20.
N11 X40. F100.
N12 G02 X46. Y0 I40. J0
N13 G01 Y-40.
N14 G02 X40. Y-46. I40. J-40.
N15 G01 X0
N16 G02 X-6. Y-40. I0 J-40.
N17 G01 Y0
N18 G02 X0 Y6. I0 J0
N19 G01 X20.
N20 X21.2
N21 G03 X22.049 Y6.351 I21.2 J7.2
N22 G40 G01 X26.461 Y10.764
N23 G00 Z3.
N24 Z25. M09
N25 M05
N26 M02
N1 G00 G90 G40
N4 G75 S2000 M03
N5 G90 G00 X13.539 Y10.764
N6 Z3.
N7 G01 Z-10. F400 M08
N8 G40 X17.951 Y6.351 F150
N10 G01 X20.
N11 X40. F100
N13 G01 Y-40.
N15 G01 X0
N17 G01 Y0
N19 G01 X20.
N20 X21.2
N23 G00 Z3.
N24 Z25. M09
N25 M05
N26 M02
E
Checking things like G81 format will have to wait until I'm back at work tomorrow, but I can't explain why you can't use G17 or G80. I think that may be a mistake on your part, perhaps you misunderstood where a syntax error was actually coming from, since the control only shows you which line has an error, and isn't more specific.
I can think of one possible reason why you might get an error with G41/G42.
In the tool setup page you can enter a tool diameter and a wear diameter. The control uses both of these when comp is turned on with G41/G42. If your posted code is for wear compensation only (which is likely) then you must make sure the tool diameter is not entered in tool setup.
bigjon61 I've recently started working on a HURCO CNC milling machine, and I'm enjoying it so far. I like the fact that it's beginner-friendly, even though I haven't had the chance to work on complex parts yet. For my current projects, I use manual programming with canned cycles, which are sufficient for my needs since the parts are not too complicated and the series is usually between 2 and 31 pieces. However, I'm finding the programming logic to be quite different from what I'm used to, and I'm struggling with it. Any help would be greatly appreciated.
I'm not ahit talking when I say this, but you gotta jump on the conversational side of the control. It's the tits. For simple stuff like drilling/tapping/reaming holes, simpler profiling, bolt hole circles, it simply can't be beat (and Haas tried). Your more complicated stuff I would run through CAM when more control is needed over toolpaths or if there is a shit load of holes. Trying to train over text would be a pain. Hurco offers a lot of training videos online, but most if not all are for the Winmax control or newer. The principles are the same but appearance and location of different menus and features are different. Still very helpful.
Not sure if you are a Facebook user or not but the Hurco Machinist Group is an excellent resource for quick guidance.
