I have a new to me Hwacheon HL-460, 17"x40" engine lathe at is about 20 years old. The dealer "went through" the headstock and stated it was "like new". There is a noise and what I would call a vibration very noticeable especially at the cross slide feed handle at about 400RPM but at other speeds also. Occasionally you can also feel a bump if you will. I have had the cover off he headstock and it is very clean. I am thinking it might be a bearing going bad. This is with or without the feed or lead screw engaged. I think it may be a bearing going out. Has anyone been in one of these or have any advice?
The selling dealer will probably be no help.
