MAGNOMOLDES
- Sep 27, 2023
O0100
N10 G11 (TEC, GEAR1) => “GEAR1” IS TECHNOLOGY NAME
N20 G11 (WIR, LT25) => “LT25” WIRE NAME IN MACHINE WIREBOX
N30 G10 P16 R-0.02 => (R=-0.02mm corner rounding radius minimum)
N40 G90 G21 => ABSOLUTE COORDENATE & MM
N50 G0 X0 Y0 => RAPID TRAVERSE TO ORIGIN X0, Y0
N60 G92 X0 Y0 I26 J15.5 (X0 Y0 determined the zero point from the workpiece; I=26mm thickness of plate and 15.5mm the height from the face of workpiece to the wire)
N70 M60 (wire thread)
N80 S502 H20 (S502= FINISHING H=20MM THICKNESS WORKPIECE)
N90 G1 G42 X-1.4237 Y8.1399
N100 G2 X1.4237 Y8.1399 I1.4237 J-8.1399
N110 G1 X2.8301 Y9.5912
N120 G2 X4.7808 Y8.7832 I-2.8301 J-9.5912
N130 G1 X4.7491 Y6.7625
N140 G2 X5.8351 Y5.8512 I-4.7491 J-6.7625
N150 G1 X7.8195 Y6.2334
N160 G2 X8.9540 Y4.4526 I-7.8195 J-6.2334
N170 G1 X7.7690 Y2.8156
N180 G2 X8.1360 Y1.4461 I-7.7690 J-2.8156
N190 G1 X9.9807 Y0.6210
N200 G2 X9.8886 Y-0.-1.4885 I-9.9807 J-0.6210
N210 G1 X7.9790 Y-2.1497
N220 G2 X7.4941 Y-3.4820 I-7.9790 J2.1497
N230 G1 X8.5319 Y-5.260
N240 G2 X7.2465 Y-6.8912 I-8.5319 Y5.260
N250 G1 X.5.3030 Y-6.3375
N260 G2 X4.1416 Y-7.1507 I-5.3030 J6.3375
N270 G1 X3.9917 Y-9.1664
N280 G2 X1.9834 Y-9.8013 I-3.9917 J9.1664
N290 G1 X0.7089 Y-8.2330
N300 G2 X-0.7089 Y-8.2330 I-0.7089 J8.2330
N310 G1 X-1.9834 Y-9.8013
N320 G2 X-3.9971 Y-9.1664 I1.9834 J9.8013
N330 G1 X-4.1416 Y-7.1507
N340 G2 X-5.3030 Y-6.3375 I4.1416 J7.1507
N350 G1 X-7.2465 Y-6.8912
N360 G2 X-8.5319 Y-5.2160 I7.2465 Y6.8912
N370 G1 X-7.4941 Y-3.4820
N380 G2 X-7.9790 Y-2.1497 I7.4941 J3.4820
N390 G1 X-9.8886 Y-1.4885
N400 G2 X-9.9807 Y0.6210 I9.8886 J1.4885
N410 G1 X-8.1360 Y1.4461
N420 G2 X-7.7690 Y2.8156 I8.1360 J-1.4461
N430 G1 X-8.9540 Y4.4526
N440 G2 X-7.8195 Y6.2334 I8.9540 J-4.4526
N450 G1 X-5.8351 Y5.8512
N460 G2 X-4.7491 Y6.7625 I5.8351 J-5.8512
N470 G1 X-4.7808 Y8.7832
N480 G2 X-2.8301 Y9.5912 I4.7808 J-8.7832
N490 G1 X-1.4237 Y8.1399
N500 G1 G40
N510 G1 X0 Y0
N520 M50
N520 M30
May someone confirm if this is the way to program point to point once I can take each point aided by AUTOCAD?
N500 G1 G40
N510 G1 X0 Y0
N520 M50
N520 M30
