Roger that I assume I need to check it twice, 90deg apart?
No, the actuator rotary union has super precision bearings inside it. If the spinny parts have any wiggle to them it will show on an indicator touching the housing.
Those bearings may be dinged up from the stress, so check for noise or notchiness.No, the actuator rotary union has super precision bearings inside it. If the spinny parts have any wiggle to them it will show on an indicator touching the housing.
We had just gotten a couple of new manual lathes in the shop. One of the guys chucked up a long piece of skinny rod with about three feet hanging out the headstock bore. The new lathes had two ranges, with low range maxing out at 225 RPM. I don't remember what high range maxed out, but it was fast. He inadvertently had it in high range, probably at top speed. The rod bent and beat the snot out of the back panel. The scary thing was a salary walkway directly behind all the manual lathes. Luckily no one was walking past. Bad setup, but safety approved it. Guess they figured the headstock end of the lathe was a safe place to walk past.It can happen in a manual lathe too, but those typically don't spin as fast.
Very True statement. These manual beast do command our respect as well. An Alarming occurrence no doubt, but most importantly, you were not hurt! Machine covers and our Pride can be patched up over timeIt can happen in a manual lathe too, but those typically don't spin as fast.
Thanks for the tips, I have all of those things.The blue pieces of sheet metal can be beat back into very good shape if you have a very stout and flat welding table. But never strike the sheet metal directly with a hammer. The small hammer marks will add little expansion stresses and make it look nasty. Always pound on a plate over the sheet. Helps a lot if you have a long piece of 1x3 steel bar and can clamp both ends over a section and wail away with a big dead blow hammer.
Pic of the outboard end of the drawtube. It is clearly borked.
I was afraid of that. I t still actuates, for now, without leaking but I don't know that I can trust it.That's not the draw tube. The draw tube ends at the chuck side of the actuator. That is the actuator.
I'd say that is completely fucked and unfixable. I'd be looking for a complete used actuator.
15” should be ok. Keep the speed in the “ sensible “ range. The last one I saw was roughly a 1 inch bar stuck out the back about 3 or 4 ft and the guy switched the lathe on without first checking what speed it was in. As it happens it had been left in the top speed range, over 2,000 rpm and the on/off switch was electronic, no clutch. So whoooosh.I have a job coming up to machine ends on 1.25" hydraulic cylinder rods.
Don't have all the details yet, but the rod looks about 48" long.
My lathe has a 3.5" spindle bore, and the headstock is about 30" wide.
I figured I could make a simple bushing I could clamp onto the rod at the left end to support it in the spindle. I'd have maybe 15" unsupported sticking out.
Is there any kind of simple rule of thumb about how much unsupported stock out of the spindle is considered OK, please ?
Bob
Notice
