GreenMartian
- Aug 11, 2023
Thanks so much. Suspected that it used an R8 after measuring (or hopeful), delighted about that. Top cover with tach is unfortunately missing. At least I know what it is now.That looks like a Hedwick. It was OEMed by Logan for a while. It has a reeves drive with the motor in the base of the column.
Mine has an R8 spindle.
That makes sense. Anyone here have experience running one ? They look like they'd be a good cross between k&t rigid and bridgeport versatile.The Asian Huron is probably a Roku, made under license in Japan in late 70's when european manufacture became too expensive
I had one very much like it but no reeves drive. It also had a a B&S taper. It was also a no-name machine. I didn't keep it because of the B&S taper.Thanks so much. Suspected that it used an R8 after measuring (or hopeful), delighted about that. Top cover with tach is unfortunately missing. At least I know what it is now.
Complete newb so right at the bottom of the curve. Runs but a good clean and lube is in order. Then instructions and some tooling. Appreciate your help.
Has it got power feeds ? I can’t see any signs of feed levers etc.Gone around in circles, lots of old posts. Is there anyone on here currently who has a manual? Found the page with the seal and belt info. Mostly I want to make sure that I'm lubricating it correctly before running it. Going to have to replace the spindle seal as it leaks and flings oil.
Would also appreciate a few good pictures of the cover, since mine is missing.
Fun bringing it home. Brought it and the Bobcat from work. It was not completely confidence inspiring picking it, had to tilt back and then slow going so as not to tip forward. Quite a heavy little thing. Left it on the sturdy pallet so that I don't have to bend down to use it and can pallet jack it to move. Will build a better base eventually.
I made the mistake of backing a “ Bridgeport “ into a corner like that once. Then I had to keyway a long shaft.
Notice
