Index Mill, Freeport Surface Grinder, Arbor Press, Horizontal Bandsaw (Franklin, MI)
Eggbeater
May 13, 2019
Clearing out estate, have bunch of tools for sale. Located near Farmington, Michigan. Unfortunately don’t know too much about history of these machines, operating tolerances/wear, etc. Would be happy to take measurements, inspect as directed if you help me with what/how to do. Looking to sell rather quickly.
1) Index Model 40 Vertical Milling Machine (pre-Wells). 1/2HP 110V/220V (8A/4A) Single Phase Motor. As pictured w/box of chucks & other tools. B&S #9 taper. Weighs about 1000 lbs.
Parts are still available for these from Wells-Index. Appears they have great customer service/reviews. Manual available as well. Apparently most of these were manufactured for the Navy during WW2. Manuals — Wells-Index Milling Machines
2) Freeport 6"x18" Hand Operated Surface Grinder Model SGS-618. I believe magnetic chuck form Production tool Supply Co National KMT 1325. Chun Tian Induction Motor 1HP 220V/440V (3.3A/1.6A) 3-phase.
Specs copied from an eBay ad (listed @$1900)
Technical Specifications:
• 220-440V3PH/60HZ
• Year of mfg. 1980
• Work surface of table: 5.9" x 18.3"
• Maximum grinding surface: 6" x 18"
• Maximum horizontal table travel: 18.9"
• Distance table to spindle center: 6.9"
• Maximum cross travel of table: 15.7"
• Spindle motor: 1 Hp
• Grinding wheel: 7" x 1/2" x 1.25"
• Spindle speed: 3450 RPM
• Overall dimensions: 47" x 39" x 64" high
• Estimated weight: 1500 lbs.
Equipped With:
• 5" x 10" fine pitch permanent magnetic chuck
• One shot lubrication system
Freeport 6" x 18" Hand Operated Surface Grinder Model SGS-618, W/ Magnetic Chuck | eBay
3) Wilton Horizontal Bandsaw - 7"
4) Atlas Mandrel Press Number 1-1/2" with standView attachment 257579View attachment 257576View attachment 257577View attachment 257575
Located in Franklin, MI. Email for more info. You haul!
