The video was very helpful. Clearly, the upper part of the scale has a problem.this is video how it works now
Maybe, but not clear to me. You would need to turn the handcrank very slowly to demonstrate that the lower part is working properly.the rest of the bits fed to the display are counting correctly
As for the LM387, you can buy it on ebay, from china, or from the US, but I don't know about the logistics of buying chips where you are. It should not be hard to find a new replacement, although with the wrong pinout. I am sure you have considered making a "frankenstein chip", where a chip with the wrong pinout is soldered into a socket using very short wires to reconfigure the pinout. There are chip selectors at US websites such as Mouser or Digikey that should give you alternatives. By "internal biasing", are you referring to using a single power supply and ground? Any single-supply op-amp that has the bandwidth and noise should serve. A quick look at Mouser came up with an MC33078 as a possible option, but I spent all of 2 minutes looking.
