Hey everyone!
I could use a little bit of actual user input/feedback to help me chose a pallet system. I'm getting ready to go into production on a couple models of knives for a customer of mine so I've decided to palletize all of the blades, handles, etc. and now I've got to choose a system to go with.
Considering that we're a job shop, not a production only shop, there's a lot of other factors I've been looking at other than sheer ease of use or swap time. In my research I've narrowed it down to three companies/options that I think would work well for us, all with their own pros & cons: Orange Vise, Pierson Workholding, and Saunders Machine Works.
Orange Vise: Vise Base + Pallets
Pros:
- Quick swap between pallet & vise jaws: Vise bases can be left mounted to the table and the jaws can be removed to mount a pallet in their place.
- Pallets are easily machined from scratch in house vs other competitors designs. (No proprietary bushings, fittings, etc.)
- Multiple styles of available pallets: Standard, Twin-Delta, and the new Ball Coupler pallets.
- Great repeatability: 0.0005"
Cons: Not as fast of a pallet swap as the Pierson Workholding system
Pierson Workholding: Pallet Base + Pallets
Pros:
- Fastest/easiest pallet swap out of the three.
- I'm already familiar with the system from using it at another job.
- Ability to really accurately locate our 4th axis if we mount the 4th to a pallet that could sit on/off the pallet base.
- Most accurate stated repeatability out of the three. 0.0002" repeatability.
Cons:
- Switching back to a vise requires either removing the Pierson base, or semi-permanently mounting a vise to a pallet which would sit on the base which takes up an extra 4" or so of my Z-travel.
- The least flexible of three.
Saunders Machine Works: Fixture Plate + Pallets
Pros:
- Fixture plate gives the most flexibility for work holding any sized work that may come through the door.
- Ability to upgrade in the future by purchasing more Mod Vises, fixturing options, etc.
- Number of pallets I can put on the table at once is limited only by the table size/space, not the number of pallet bases/vise bases that I have.
- Fixture plate + Mod Vises setup takes up less Z-travel space giving me more room. (I've used up almost every inch of Z on a few jobs in the past).
Cons:
- Slowest pallet swap time out of the three. (4 bolts to tighten/untighten (SMW) vs clamping vise base (Orange) or pushing/pulling one air release (Pierson).
- Lowest advertised repeatability out of the three: 0.002" (two thou, not two-five tenths)
Overall I would say that the Pierson Workholding system is the best for pallet use, but the least flexible, the Saunders Machine Works Fixture Plate + Pallets is the most flexible but the worst out of the three for pallets, and Orange Vise is a happy medium of the two sitting somewhere in-between.
If I were doing purely production on verticals I would go with the Pierson system for sure, but because we run a job shop flexibility is really important to me so I'm leaning more towards the Orange Vise or SMW options.
Price isn't really a consideration since all three options with a 'base' of some kind + two pallets are roughly the same price. Pictures below:
Price/pallet is roughly the same for additional pallets. The Pierson & SMW pallets are roughly the same price at $210-ish each depending on size. The Orange Vise ones cost more at $270-$350 for a comparable size, but they're also the easiest to make in house.
Do any of you guys have experience with any of these options (or others I haven't mentioned) that you'd be willing to share to help me make a decision?
Thanks so much!
Pros:
Pros:
Cons:
Pros:
Cons:
Thanks so much!
