huntinguy
- Dec 17, 2006
- Washington
So, I would think, if i turned a spud in lathe mode, then put my test bar in the milling spindle and rolled it to 90 degrees, put an indicator on the spud and sweep in the test bar, I should be able to put the indicator on the test bar and the spud should sweep in at zero as well. In short they should be in perfect alignment.
They are not... Y is .0035 tir and X is about .0085 tir. When the other is reading 0,0.
What am I missing?
(B is parallel within .0003 in X and Y over the length of the test bar. Runout on the test bar is .0002 and about the same on the spud).
What am I missing?
