Win7 and Win10 machines. Not sure on the exact version of USB, I didn't think it mattered.
One thing about the device with the D4 - His instructions are to insert the stick, choose the directory via the selector on the front of the device, THEN turn the power on. Due to some peculiarirty of the D4 port, I need to turn the power on, THEN switch to the directory I want to load from. Dialog is not the only machine that requires this, but I've forgotten the explanation why. I sent Jerry my cheatsheet of the procedure on the Deckel, I think he'll be able to address it with you on the Bluetooth device if you want to go that way.
I also have a cable strung that I used to use, it's been abandoned since I got the USB installed.
I like the USB because I can upload and download all i want, then walk to the office with the stick instead of running back and forth in the event of an error. I can put up to 10 programs on the stick at one time.
He sends a wall wart to power the device, I connected it to 24VDC inside the console to avoid having another wire dangling around.
I have these on 2 machines, zero problems.
