AdamPrince2
- May 10, 2011
- Honeoye Falls, NY
I have a table servo for a bridgeport knee mill. I plugged it in and the forward and reverse lever with the rheostat did not work. However, upon pressing the rapid transverse button it did move. Then some white smoke came out so I stopped. Does the vacuum tube look burnt out?
There does seem to be a glass tube just above the resistor at the bottom left. But it's not a "traditional" vacuum tube, perhaps it's a relay/switch of some form?There is no vacuum tube in the servo control.
could well be a neon light, that was my guess but the picture is not good enough to tell. It's unlikely to be a mercury switch unless the unit tilts somehow and it is using microswitches as the switch technology. It looks like the wiring smoked, probably a short to ground.There does seem to be a glass tube just above the resistor at the bottom left. But it's not a "traditional" vacuum tube, perhaps it's a relay/switch of some form?
could well be a neon light, that was my guess but the picture is not good enough to tell. It's unlikely to be a mercury switch unless the unit tilts somehow and it is using microswitches as the switch technology. It looks like the wiring smoked, probably a short to ground. It is a fairly basic scr/triac speed control, it should not be hard for an electronics person to fault find, but parts may be difficult to get.
I have seen a lot of old electronics, but it is really hard to tell what that is from the photo, which is not very sharp. There were some tubes that had wire leads instead of a socket mount and it could be one of them. A big clue would be the number of wires going into that glass envelope. If it is just two, then it is certainly not a tube. Three wires would be a bare minimum for that. But if it has 3, 4, 5, or more wires, then it probably is a tube.
Also can you see anything inside the glass? Relays have contacts that move. And a coil to move them. Tubes usually have a central heater element, possibly a cathode that surrounds that heater, and at least a plate that surrounds everything else. The plate is usually shaped like a tube that's around 3/4s of the tube's diameter and about 3/4s of the inside length.
From the looks of that thing, I would chuck it in the trash before it burns my shop down and build a new control from scratch. If it just controls table movement, it can't be very hard to duplicate.
Glass doesn't burn. If that was a tube, and if something smoked, it wasn't the tube. Try cleaning all the spooge off the board and photograph again.
It just has two wires. Looks like cutting oil entered it. I will clean the board and desolder the light and check for continuity.
..and your helpful post is where ?It sure is interesting to see the electronic answers by machinists. :-)
lewie (retired electronics engineer) :-)
Notice
