guythatbrews
- Dec 14, 2017
- MO, USA
My across the street neighbor has an old Sea Ray jet boat. The impeller/housing is worn out so he's looking for a repair. This is NOT a money maker. We do each other favors turn and turn about so I don't mind, even though I'll probably spend a bunch of time on this.
The aluminum housing is too worn to get sufficient jet to drive the boat. The impeller is SS and he has worked it over so it is likely smaller than stock. The housing might be welded up but with that much weld the distortion on the remaining features will be horrible. Maybe spray weld but I don't have a vendor. He says he can get some sort of plastic insert made for the purpose. Bore the housing and insert the liner. Liner is supposed to be 6mm thick and hopefully the liner vendor will supply the housing bore size. Our lakes are not sandy so a plastic insert should last a while and can be replaced, so maybe not a bad option. If I had a piece of tube the right size I'd just loctite a sleeve in place, but I've none and short pieces of tube just the right size are hard to come by for free/cheap.
My guess is the bore and the impeller are simply cylinders with a close gap. So I'd bore the housing, install the liner, maybe bore the liner, and turn the impeller to fit.
Can anyone confirm these are true cylinders? Anyone done this or have a better repair method? Any idea of appropriate gap size?
Again, just a favor for a buddy and not a money deal. In general I don't do repair work.
