Look at the drive gear that plugs into the spindle.. If it has a disc on the front of it, It needs the special installation instructions...The older std hi speed heads could move away from the column via splined shaft, and they used the disc on the drive/driven gear to maintain proper backlash of the gear teeth... Cheers from Louisiana... Ramsay 1I am looking at a K and T 2HL plain at the moment...seems to be in good condition from pics. I am reading this thread gleaning all the info i can. I don't think it has the high speed mill head on it but the thread on how to mount the high speed head i found interesting and something i am curious on how this mounts up correctly. If it isn't indeed a high speed head i assume u can just mount to overarms and then tighten to column and the gear meshing is set. Not sure if u have to doView attachment 390178 something where u raise or lower the head a little to get proper mesh of drive gear.
I am looking at a K and T 2HL plain at the moment...seems to be in good condition from pics. I am reading this thread gleaning all the info i can. I don't think it has the high speed mill head on it but the thread on how to mount the high speed head i found interesting and something i am curious on how this mounts up correctly. If it isn't indeed a high speed head i assume u can just mount to overarms and then tighten to column and the gear meshing is set. Not sure if u have to do something where u raise or lower the head a little to get proper mesh of drive gear.
it's a 2HL. Says so right on the side. The only difference would be the size of the table.This is a model H from the late 30s or 40s but with a later generation head and overarm support. The styling of those make me think they were from a S series machine of the 1960s. Which isn't an issue but I did think it was intesting.
Correction on the vertical head.. It is a later model with the drive gear attached to the drive bracket.. 1h and 2hl are basically the same except the 1h has a smaller table.. 2h has larger table, wider column and larger overarms.. I know as I own both... Should be pretty straight forward on mounting the unit to the machine... I have enclosed pictures of the unit though the moveable quill unit it shown it is available with fixed quill as your unit is....Cheers; Ramsay 1This is a model H from the late 30s or 40s but with a later generation head and overarm support. The styling of those make me think they were from a S series machine of the 1960s. Which isn't an issue but I did think it was intesting.
I'm not convinced that's the same one pictured. There's no opening in front where you should see the overarms. Unless they painted them blue!Correction on the vertical head.. It is a later model with the drive gear attached to the drive bracket.. 1h and 2hl are basically the same except the 1h has a smaller table.. 2h has larger table, wider column and larger overarms.. I know as I own both... Should be pretty straight forward on mounting the unit to the machine... I have enclosed pictures of the unit though the moveable quill unit it shown it is available with fixed quill as your unit is....Cheers; Ramsay 1
The one pictured may be from a larger unit.. 2hl has small overarms so maybe not much to cut away..... I must admit I have not seen this type on a small mill as usually the older type is used...Ramsay 1I'm not convinced that's the same one pictured. There's no opening in front where you should see the overarms. Unless they painted them blue!
OMike...are there rpm limits with this later millhead??? when the owner shot some video and the mill reached 1088 rpm the spindle ground to a halt....all lower speeds seemed fine. He claimed 'heaters' were the cause. He switched from 3 phase to single phase 3hp motor so higher amps of single phase tripped heaters set for lower amps of 3 phase. (btw imho when heaters trip everything stops and need to be reset) and hadn't adjusted the heaters for the higher amperage of the single phase motor. I have to think that this isn't the case since the motor was still running in back ground. Could it be the mill head is not a correct match for the mill? Here is a video of the spindle bogYep, parts book pub 258A shows blind holes for the overarms in bracket type "U" for these small mills. Specifically calls out as fitting mills 1CH, 103CH, 2CHL, 203CH, 18AC, 18CH, 103CHP, 24AC, 203CHP. Pretty interesting as I didn't know they even made a 103CH I don't recall seeing it in a catalog. I had kind of assumed the smaller mills had been discontinued by then.
Just for those that don't know K&T made a number of different heads of different sizes and features. Then they made different brackets for those heads for different mills. So a head of one type may fit different sizes of mills when ordered with the correct bracket.
@MyLilMule i was gonna ask u if u had the high speed version of mill but u clarified that....from my reading a mill head if it is compatible with a machine should be able to handle the rpms. Your mill head doesn't have the drive gear though correct?
sorry for thread high jack @MyLilMule but great learning here all around.
Notice
