We just acquired a K&T 5HP-2CH vertical from another department on campus that was changing to CNC equipment. It has the mono lever and automatic cycle table control. It appears to be stuck in rapid. The rapid lever does not do anything, if any of the power feed levers are engaged the axis automatically starts moving in rapid, no change spindle engaged vs disengaged. I was wondering if anyone has experienced this before or had an idea of where to start troubleshooting, or if there is a way to disengage/remove rapids all together so the machine can just be used with normal feeds.
Thanks,
Tim
Thanks,
Tim
