That's an option I hadn't thought of, thank you for that.If you have a lathe, you could put the spindle in the lathe and cut or grind the race down to the spindle diameter and fit a new bearing.
I dont know how hard the spindle is.
Now I'm gone, I hate to see that head sold for parts.
I dunno where the cracks are exactly, but I have a drive bracket for a 2h 2ch that I bought on Ebay and it is cracked near the driven gear section.. I brazed it up and it runs fine... It cracked in a thin section by the gear.... Cheers from HOT Louisiana; Ramsay 1I'll add that this head as other problems besides the bearings. Like two cracks in the bracket that holds it on the overarms. All of these issues pile up.
These cracks are on the swivel support bracket, inside the bore where the over arm supports go. Although they don't show up on camera as bad as they appear in person. Pretty thin material here. The plan, I hope, is to grind out the crack, TIG braze it, and refinish the bore. My concern is that this will affect rigidity. Coupled with a junk bearing and race, it's going to become accumulative. The more I can eliminate the better this accessory will be.I dunno where the cracks are exactly, but I have a drive bracket for a 2h 2ch that I bought on Ebay and it is cracked near the driven gear section.. I brazed it up and it runs fine... It cracked in a thin section by the gear.... Cheers from HOT Louisiana; Ramsay 1![]()
This is not an option. It's hard to tell from my photo, but there isn't enough material between what the spindle would be if it was straight and the internal 40 taper. With this design, it keeps the bearing and ultimately the head smaller.If you have a lathe, you could put the spindle in the lathe and cut or grind the race down to the spindle diameter and fit a new bearing.
Some K&T spindles have the inner race ground onto them.. People call Ron Grundy who worked at K&T for 30 years and tell him they can't get the inner race off...Rollers run on the spindle on some of them....It is a good way to add rigidity and make the spindle more compact, but I suppose the entire spindle must be changed if it is pitted or fretted... Cheers from HOT Louisiana... Ramsay 1This is not an option. It's hard to tell from my photo, but there isn't enough material between what the spindle would be if it was straight and the internal 40 taper. With this design, it keeps the bearing and ultimately the head smaller.
I understand the the bearings were assembled by putting the rollers into a partially crimped cage. They would be slid over the spindle, and the a special tool was used in an arbor press to crimp the top of the cage.
Notice
