5/21/2018 - Compressor installed by Kaeser, $7235 with spare filter set and startup labor
5/24/2018 - Solenoid valve replaced
5/31/2018 - Vent valve replaced
7/26/2019 - Kaeser planned service, motor bearings are bad
9/13/2019 - Replace motor under warranty because they had a bad run of motors
9/24/2020 - Kaeser planned service, first and only service call where no problems with compressor are found
10/19/2021 - Kaeser planned service, tech agrees air end sounds like shit. Belts and oil ok, motor bearings sound growly
11/10/2021 - Kaeser salesman says in email, "Wow, I agree that it is not normal to see that kind of wear in a machine that only has been used for 5,680 hours." and said during a phone call, "even if we were under utilizing the compressor really badly, an air end should fail at 8-10 years, not 3".
11/29/2021 - Kaeser quotes $4,410 to replace air end and $764 to replace motor ($5174 total, 71% of the total original cost of the compressor)
12/10/2021 - Kaeser tech comes to verify issue, no obvious reason air end should have gone bad. Oil is good, mechanical systems are good, environment is outstanding.
Jan/2022 - Kaeser 'master tech' comes by unannounced to verify issues. Never got paperwork from this visit, but he confirmed that there is no obvious reason the air end should have failed. Oil is good, mechanical systems are good, environment is outstanding.
2/23/2022 - "...this claim was denied due to no longer within the warranty period." FOUR MONTHS to deny a warranty claim.
