Rapid_Tech
- Oct 27, 2014
- Toronto
Hey Guys,
I was wondering if anyone has had a similar problem with their Kaeser compressor. The unit in question is an 2015 SM-10 with the intergrated dryer & receiver tank and has close to 10k hours. There's also an additional 200 gallon storage tank. Maintenance is up to date, I did a full service on it replacing all the filters and oil about 3 months ago.
For a while now it would give a back pressure alarm. It's fairly random when it happens, once every 1-3 days. I've changed the solenoid and vent valve assembly, based on the recommendation from the Kaeser dealer in my area. It helped initially for a few weeks but the problem has returned and is happening more often.
I'm now wondering if the pressure transducer is the actual culprit? When the compressor is running, the pressure on the screen builds normally to its limit of 125psi. As soon as the compressor unloads, the pressure drops to 107-110psi in a split second. I mentioned this to the Kaeser service tech on the phone but the only answer he gave me was that there was a large demand of air in the shop . I explained to him several times that it would do it with no machines turned on and no air being used. Even if all my machines are on, there's no way that it would drop 15+psi in less than a second from a system with a 250+ gallon capacity.
Thanks in advance for any help.
