WakelessFoil
- Aug 18, 2020
We wanted to try our hand at boring on a vertical mill using one of our larger boring heads. Time after time, our results were unfavorable. Something unbeknownst to us at the time, was causing our spindle to become uncentered with the hole we were trying to bore. We have finally found our culprit.
We learned that the head assembly of the mill we were testing on (K&T 2CH) was shifting back and forth about .010" when cranking the head up and down. I tightened the single gib-screw on the head assembly to see if there was any improvement. It is now down to .003" of linear play.
Has anyone had experience with this problem on similar machines? How did you go about fixing it?
Does anyone have a copy of the manual for the 2CH? I see copies online but of course they want money for a digital copy of a machine tool manual from the 1950's.
Thanks,
Justin
Thanks,
Justin
