You mention buying multiple vises. This suggests that you want them for mounting longer parts on one mill.
If you want the bed heights to match, particularly if you buy the vises at different times, then make sure that is a published specification WITH a TOLERANCE.
I purchased two Shars brand vises, which use the Kurt style, jaw pull-down, at the same time. Economy was a big concern so I took a chance. I don't do a lot of long work and much of it that I have done in the past was for electronic front panels with through holes so small differences in bed height did not matter. Also I could always make a shim to fit over one bed and that is a lot less expensive than paying an extra $500 or so per vise. As luck would have it, their bed heights did match fairly well, but that was luck, not a guaranteed spec. Kurt and most of the expensive vise brands do provide that spec.
Edit: I see you are using pallets. I would think the same things would apply there.
