hvnlymachining
- Jun 21, 2019
- St.Onge
Hello ladies and gents.
I'm currently trying to get a couple of quotes for one of each of three gears for a 1920s skid mounted winch used to move rail cars into loading stations.
The large gear is a ring gear, 36 3/4" in diameter, 72 teeth ( appears to be) 14 1/2° Pa, and was told that makes it a 2 DP. With about a 30" bore. ( Forgot to bring the dimensions home and can't remember this one) 4 3/8" face width.
The other gears are 15 tooth, drive and sliding engagement gears mated to the large one.
I've made quite a few phone calls with little luck finding a shop interested in the job.
If need be I can make the smaller ones on my horizontal Cincinnati no3, but that 36+ gear is just too big for my mill and I don't recall seeing a way to cut gear teeth on a lathe.
Any information would be appreciated. If anyone here is interested in quoting I can add more info and... pictures.... ( Still trying to learn this new format)
Thanks
Jacob.
Thanks
Jacob.
