Large size slotted roll (spring) pin
rich-machine
Mar 4, 2013
Louisiana
Gents
I'm working on a large German manufactured roller mill and urgently need 40 mm OD x 26 mm ID x 50 mm long slotted roll pins. I've searched online and do not see any roll pins of such size. Most vendors stock much smaller sizes.
Does anyone know where I can source such a part? The OEM lead time is too long.
Pics attached
gbent
Mar 14, 2005
Kansas
What is the usage? It looks more like a split bushing than a roll pin. Is there a shaft through the bore? Is it hard? (file test, sound)
Jun 23, 2017
See if you can order an ejector sleeve and split it with a abrasive cut off wheel.
ratbldr427
Mar 21, 2006
jacksonville,fl.
That appears to be precision ground and is most likely hardened. Maybe get some solid stock and drill and spit. You might be able to get 40mm oversize prehard stock if you are worried about hardness.
I work on a lot of German equipment with all kinds spit & roll pins but have not came across any that large.
I can under stand not wanting to vary from oe on expensive equipment.
john.k
Dec 21, 2012
Brisbane Qld Australia
Definitely a special part ......not rolled from sheet as is a roll pin ,but solid machined and slit .......Id suggest you make your own .,or reuse what you have .
rich-machine
Mar 4, 2013
Louisiana
Thanks all, its part of a large bearing assembly. Looks like making a new one will be the only option unfortunately. I'll see what my local machine shop can do. I am reusing 3 of the 4, one of them was damaged during removal.
ratbldr427
Mar 21, 2006
jacksonville,fl.
may want to get your eyes tested, doesn't look like it's been within 50' of a precision grinder of any sort
Ok expert tell us how it was made. It appears to have been finished to size and fractured. All the smaller pins I have worked with that were called "precision fit" (which in this case a relative term) were rough ground finish. Never seen a turned finish but have never had a 40mm one.
Bill D
Apr 1, 2004
Modesto, CA USA
How do they get removed? Are they internal threaded for a slide hammer. Might add threads to the new one before it is hardened. Or an internal groove might help next time. Just make the groove far away from the parting line in the casting. Likely near top or bottom of the pin
Bill D
Joe Gwinn
Nov 22, 2009
Boston, MA area
Is it magnetic? If it's steel, it cannot be compressed in OD all that much. Maybe some kind of bronze?
L
Luke.kerbey
Guest
See if you can order an ejector sleeve and split it with an abrasive cut off wheel.
an ejector sleeve is hardened anx made from a different steel. and not designed to deform. It would likely crack instead
Jun 23, 2017
Ejector sleeves come in all types of states and materials. Soft, through hardened and nitrided.
L
Luke.kerbey
Guest
You learn something new everyday… I’ve never heard of soft ejector sleeves!
