Azoth
- May 10, 2019
- Houston, TX
So 3 specific concerns.
Not talking aluminum. Say working with 25-30 hrc steel:
How much stock do you leave for finishing walls? Just a couple thou, or a certain percentage of tool diameter based on axial depth?
How do you calculate feed rates for surface roughness on faces and walls? On a lathe it's easy to calculate the surface geometry you will create based on tool nose radius and feedate, but the swirling bottom cutting action of the endmill (or facemills) make it more complicated. And my sidewall finishes don't follow the rules either (.004 IPR with a .5 radius lathe tool calculates to 1 RA, but a 1 inch endmill at .004 IPT clearly isn't that mirror-like since it leaves a distinct waviness presumably from tool vibration beating the part up.)
How do you handle an endmill breaking in corners? In this case, 44° included angle with a 3/4" - 5 flute endmill at 2" axial depth, .080" stepover. Do you speed up to reduce cutting forces or slow down to reduce chatter? Rough with a high feed mill and small step-downs instead and only ever load up the length of the endmill for finishing and never roughing?
