13engines
- Jun 30, 2015
- Saint Paul, MN
I just finished rebuilding a couple KSC branded Z axis two side live tools for my Mori. After running them in, I took the cover off an identical unit that I have to see what a guy could see, and found the spiral bevel gear cavity completely topped off with grease. (This one I had bought off eBay.) I must have pulled a pint or more out of there. Looked like an off white lithium number or something. I had used small-ish quantities of an EP marine grease on the gears and Kluber on the bearings.
My question... is this how the gears in these live tools are supposed to be greased? I've always been more inclined to less-is-best. There is very little if any info out there on rebuilding these tools, so I'm asking. One face of the largest main bearing is exposed to the cavity. There's no way I'm going to put a pint or more of Kluber in there. ($$$$) Filling that cavity full with a different grease then the bearings would leave me with a much great possibility of cross contamination with the two greases. The little I put in there sprayed the walls a little and that's about it.
On the two I rebuilt, one was full of coolant, and the other was full of rusty, near frozen bearings. No remnants of a pint of grease in either of them.
UPDATE: I just took the cover off another unbranded Z live tool I have and it was also full of grease. Another off white grease with more of an NLGI 1 thickness to it. I think this one had also been rebuilt by someone as it had a silicon type gasket sealer on the cover leaving a small ting around the cap that didn't strike me as being factory.
Can anyone give me a definitive fill or don't fill? Help........
