Hello guys, hoping somebody might have a few ideas.
I have a 1993 model Kingston HJ-1700 and I'm having problems keeping the large spanner nuts that set preload on the spindle bearings tight. There are two opposing tapered roller bearings (circled in red) on the chuck end with an adjustment nut (circled in blue) behind them and a third support bearing on the outboard end. The nuts have a grub screw that pushes a brass plug against the threads to lock them in place after the adjustment is made.
Twice now I have removed the cover and found both nuts almost a full turn loose, with a gap between them and the bearing. The last time it happened I painted witness marks on them and verified that they are indeed turning in relation to the shaft. If I back the nuts off and tighten the grub screws, it takes quite a bit of force on a 12" long spanner to turn them, but it can be done. Shouldn't really take that much to keep them in place though.
The previous owner mentioned that they had made multiple adjustments over the course of the machines life and I replaced the bearings after I got it thinking maybe they had just worn. The bearings don't seem to be moving on the spindle, the nuts are just rotating away from them.
If anybody has ever experienced this or has any ideas to look at, I would appreciate the insight.
Thanks
Thanks
