Lathe system variables list, Different than mills?
GiroDyno
Apr 19, 2021
PNW
Trying to use the WCS system variables on the lathe to calculate some main/sub transfer positions, but the usual values arent working
Like #5223 is G55 Y (not Z) value, and #5224 is NOT G55 Z...
Also according to the manual they go #5201, #5221, #5261? #5281 so not the same as mill variables.
hopefully this helps
ngc control is left and legacy control is the right hand side.
#5201-#5206#5201-#5206G52 work offsets
#5221-#5226#5221-#5226G54 work offsets
#5241-#5246#5241-#5246G55 work offsets
#5261-#5266#5261-#5266G56 work offsets
#5281-#5286#5281-#5286G57 work offsets
#5301-#5306#5301-#5306G58 work offsets
#5321-#5326#5321-#5326G59 work offsets
I looked in the lathe operators manual
Thought it was strange they start at a different value than mills, and that they skip around:
Rather that troubleshooting and guessing I made a program to populate all of the WCS variables so I could figure out what I actually need to use, like #5201= 5201...#7386= 7386 and found some interesting results!
1) Turns out that's a typo in the manual and they start at 5221 like a mill and not 5201, so there's no skipping from 5021 to 5061
2) I also found they use a different order, not #xxx1 = X, 2 = Y and 3 = Z
On a Haas lathe:
#xxx1 is still X
#xxx2 is now Z
#xxx3 is changed to Y
Kinda makes sense since Y axis is not used a frequently as X or Z, but would have been nice for that to appear in the documentation somewhere...
Who knew!
On a Haas lathe:
#xxx1 is still X
#xxx2 is now Z
Who knew!
Yea the 5201-5206 are used for g52 if your machine has that option not g54.
On a Haas lathe:
#xxx1 is still X
#xxx2 is now Z
Who knew!
What version manual did you get that from?
Looks correct in mine. Dec 2017 manual
The ones that's posted on Haas website...
I must be some kind of dumb idiot for thinking Haas would post accurate information about their own machines! I should have known better.
