p3bhambama
- Jul 5, 2023
Perhaps so. Mine has a foot in the middle maybe to prevent just that though it’s only 12x18 so no ideaBesides that I expect it will sag into flatness on it's own weight.
No if it's a 3 point surface plate 18 x 18 with ribsike a Bush or Challenge it won't sag, just that's where it's used the most. If it's a bench plate used to emery cloth something. It might sag. I was looking for the used more in the middle answer.Besides that I expect it will sag into flatness on it's own weight.
That's a good visualization - basically what I did. I also find that it's really important to sort of "get my mind right" about a pass before I make it - and not to just start scraping and decide on the fly what to scrape and what not to. Taking a few minutes to wipe off the grey blue and really have a plan as to which areas I'm hitting on the pass results in a better pass. Each cycle I get better at recognizing what is needed. Also being able to recognize what is a false print has been important - I've generally been ignoring any marks that are a little bit smeary as I find that often indicates a false blue.I think about a target practice target when scraping square plates high in the middle. Outside to inner circle. Center 3 times. Then 2 times and then 1 on 3rd ring.
Yes I've watched several of his videos. Very good content and obviously was taught well...We call a smear a "false reading". After you learn a bit more knowing where to scrape and how much to take off will become 2nd nature. Lol. People are amazed how I can look at a picture and know it high in the middle. But I've been hand scraping since the 1960's. One of my best students calls me the professor on his YouTube shows. He has probably over a 100 on rebuilding. Jan Sverre Haugjord over in Norway. He has both English and Norwegian versions. He's taken 5 or 6 in person classes.
Sounds good. I’ve actually been thinking the same thing in as far as a different project.I'd say, start a new project like a straightedge. Buy one from Denise or Martin Models. Or buy some cut Dura a Bar . I have some longer prime I could say sa a 12" piece off. I could give you a deal...you will learn more now on something else, the go back to the plate after you refine you skill. As far as Kieth using the magic marker. That's a lousy way. I never mark high spots by dabbing them. I lay out lines to get the checkerboard or mark area not to or where to, depending on the circumstances.
Continuously cast cast-iron bar. (Durabar is one manufacturer)Sorry for my ignorance, what durabar means?
Notice
