I did not even suggest that. I needed some gears a few years ago and they averaged 1500.00 each!I'd say you could probably buy direct replacements from LeBlond Ltd., but you'll likely want to be sitting down when the price quote comes in...
I'm glad to know this. All of the slow speeds on my Tray-top are worn. They are straight cut gears so I was hoping to find replacement gears one day. Maybe Boston Gear?Things to know about measuring gears
These are easy in that they are "straight cut" rather than helical
They will have a DP - or diametral pitch - this determines TOOTH SIZE
A way to find DP:
Measure OD with mic
Count teeth - add 2 to the count
Divide OD into tooth count plus 2
Example"
2.125 OD divided into 34 = 16 DP
Gears are usually damaged in pairs, so replace them in pairs as well.Be aware of what I said about lathe gears not conforming to standard dimensions.
Many years ago, a friend who worked at LeBlond Ltd. suggested that shaved or hobbed gears would be less costly than their typical hardened & ground gears. You might suggest that approach to LeBlond Ltd. A pair of hobbed gears might be a bit noisier than a ground set, but would function well.I did not even suggest that. I needed some gears a few years ago and they averaged 1500.00 each!
Notice
