rimcanyon
- Sep 28, 2002
- Salinas, CA USA
LITTON "Q" Lathe.
This is a small VS lathe with a D1-3 spindle and a joystick to control the hydraulic tracer. It was originally designed for making vacuum tube bases, and it has a lot of flexibility. The hydraulic tracer works, but it can be removed and an X.Y carriage bolted in place for normal manual operation, or the hydraulic components can be replaced with ballscrews and converted to CNC. It h as a Reeves drive and is equipped with a 3phase 220V motor. It has a small footprint (30" x 30" at a guess), and stands vertically on the floor with the bed projecting out to the right.
The cross slide has a top dovetail that is identical to the one on some 10EE cross slides, so it uses the same rear toolposts as a 10EE.
The way the lathe is designed, the lathe has a sub-bed with t-slots designed to take a variety of tooling. So if the hydraulic tracer carriage is removed, the sub-bed is exposed and you essentially have a VS polishing lathe with D 1-3 spindle and a platform to mount any tooling you want. The headstock also has a opening parallel with the spindle to hold a ~3" bar, so a threading attachment from a chucker could probably be adapted to it.
Price includes a D1-3 5 C spindle nose and a lever-operated collet closer, all made by Monarch for this lathe. The 5C spindle nose also fits a 10EE.
If you want to inspect the running lathe it is in my shop in Salinas, CA
There are some photos on the net, google litton Q lathe.
