Long Length Endmills
Miller846
Oct 23, 2022
Hi, I am curious what all of your thoughts are on this. I need to machine about 80 aluminum blocks, roughly 3.5” x 4” X 5”. My plan is to just face the top and drive around the sides with a 1” Diameter Long Length endmill. But I am concerned about chatter doing something like this. Has anyone ever used a reduced shank endmill and taken step downs for profiling thicker stock? I’m curious if it would leave lines at each step down or if it would leave a better surface finish than a long length. Unfortunately, I currently only have a 3 axis mill, otherwise I would just face mill each side. Let me know your thoughts, thanks!
Milland
Jul 6, 2006
Hillsboro, New Hampshire
With a decent CNC mill and setup, and especially with a 1" carbide endmill on aluminum, sometimes just a spring pass or two will get you a good perpendicular cut. But finding the "sweet spot" for S/F for the finish pass can take some experimenting.
I usually vary the height a bit, perhaps .010" high on the first spring, then final depth on the second.
MCritchley
Mar 22, 2007
Milwaukee
I use relived shank cutters from Helical tools for stepping down the perimeter on Al parts often. I’ll hold the work piece with some Talon grip jaws, face the top and step mill the sides. That process leaves me with five milled sides that are within a thou of perpendicular and parallel. I always have a 3” reach endmill mounted so I can mill a 2.8” tall part. The steps are there, but you can hardly detect them with an indicator of profilometer. And while I’m at it I’ll chamfer in the machine so I don’t need to debur by hand.
I’ll mill off the waste on opp 2. and chamfer that side also.
Stepping down is a very efficient and controlled way to mill a part. Full length endmills are not as stiff as a relived shank tool and as others have said will leave a tapered wall.
DavidScott
Jul 11, 2012
Washington
The end mill matters. A 7+ flute will work much better than a 3 flute since it has soooo much more core strength. I say a full length cut is doable, depending on what is holding it.
crossthread82
Apr 1, 2022
Maryland
I wouldn't be attempting that in one cut unless you're using a 5+ flute endmill, something like the AF5 from Swiftcarb. 3 flute at that L to D ratio is starting to get flimsy. I ramp contour with necked endmills all the time. Is it going to leave a mirror, no. But the step downs are very minimal and you can't feel them at all, just kind of looks like a light shadow on the wall. With an endmill over 4xD you'll need a spring pass to bring in the perpendicularity. With a necked tool its likely not necessary.
The key with a necked tool is to ramp down the wall instead of depth cuts. That keeps the tool in contact with the wall at all times, making it more seamless.
OVodov
Sep 10, 2019
If looking for perpendicularity you will need not only tool but holder too.
Shrink fit or hydraulic would be the best.
For rough I would say to use long chipbraker.
For finish take the tool with 5 flutes.
Kennametal KOR or similar Helical or Imco. I love Imco
OVodov
Sep 10, 2019
I have used OSG 4 flutes for long reach finishing in precision bore and got perpendicularity to face within 0.0012 along 3”.
So use as many flutes as you can find, it gives better flatness, but keep it in mind to hold it perfectly.
And use it only for finish, Endmills with many flutes don’t have room for chips.
MCritchley
Mar 22, 2007
Milwaukee
YG-1 Alu-Power extended reach/necked will blow your mind how seamless it can be. I rough it leaving .002" then Helical ramp around the profile until it reaches the bottom. Never seen a sharper end mill.
What is your typical ramp angle with a .002” cut?
13engines
Jun 30, 2015
Saint Paul, MN
I can't answer for D smith, but common sense would say your -Z move would be just shy of one full flute length per time around the part. That is if the part periphery was long enough. At 0.002 of material to remove, I doubt there is any angle sharp enough to be bad for the cutter like it might be for ramping or helical milling into solid, but there could be an angle too sharp to give a usable finish. Perhaps D smith has the answers for that. I haven't tried this yet, but it isn't a bad idea compared to running a very long end mill.
After further thought, how do you get past the double cutting that will have to occur at the beginning and ending of the tool path? Is it cut one flute length and then a quick ramp to the next level? This would make your transition areas move around the periphery of the part as you progress down each level. Hopefully D smith can explain.Or anyone for that matter.
couch
Jun 10, 2009
Anaheim, California
How deep do you actually need to cut?
Have had real good results with solid carbide endmills in hydraulic holders going around 4” deep. Under a thou total taper side to side in aluminum with nice finish, no chatter. Rougher in an ER32 (no reason other than I have a bunch) than finisher in the Hydraulic. Would easily go deeper especially if I bumped it to 1” diameter. Slow rpm (around 2500rpm), slow feed and clear chips before the finish pass either manually or with good coolant flow or air blast with coolant. Also ran a spring pass.
Unfortunately can’t show the parts with any detail, may be able to take some photos of one of the setup pieces that I still have though to show the sidewall finish if interested.
Long story short, run a long tool, dial in the runout and don’t try to spin it too fast. Will work fine, it’s aluminum.
DSMWerks
May 7, 2005
Prescott Valley
When I use Z ramp profile to finish pass with YG-1 Alu-Power I go about 3/8"-1/2" ramp per pass. I don't use the same end mill as I roughed with so the finish end mill is razor sharp. On a 3/4" Alu-Power Extended reach the cut length is 1" and the solid shank does a great job of not flexing. To me its all about the razor sharp edge. You can have 6-7 flutes but if the 3 flutes on Alu-power are twice as sharp it will do a better seamless job.
crossthread82
Apr 1, 2022
Maryland
Flute count doesn't really matter if the tool is necked since the solid shank is supporting it. In long LOC endmills though, flute count is everything b/c that's where all your strength is coming from.
