Richard King
- Jul 12, 2005
- Cottage Grove, MN 55016
Check out Lucas or Bullard as they also made machines that had side rails in the base.
If you want/need a machine that’s not too big but with a good “ x “ or cross travel your best bet is a “ planer“ type machine. Basically a “ T “ shape bed with the column moving in and out. The travelling table is supported all the way by the bed so you can get bit cheaper on the foundations if money is really tight.Doug, dial it back a little buddy. Maybe have a coffee break and relax a little. Tyrone's a good guy.
A large 'x' travel machine will probably not be available without separate outriggers. The biggest machines have a couple on each side, and they need them for the amount of weight the tables can hold. Doug is completely correct that it's very important to have a rock solid foundation if you're going to be doing work this size, or the whole machine will flex and rock/settle when the weight goes from one side to the other. What do you suppose happens when you're machining a long surface with an endmill and the machine is moving in that way while you're cutting? Sitting atop a concrete floor is not good enough. The floor will also flex and eventually crack.
A “ Lucas “ would be a good bet. I’ve seen photos of a few of the older ones that had a “ wing “ type bed.Check out Lucas or Bullard as they also made machines that had side rails in the base.
Read what the OP says In his post. “ A simple manual machine is what is all that is needed “. “ A machine with outrigger rails built into the base would be great so installation would be much cheaper “. “ We have long weldments to re-machine “.I can only go by what the OP says.
YOU can ASS-U-me all YOU want All day long.
Either way, YOU aren't helping much are YOU ?
Thanks for all the replies. Tyrone understood what I said. As I said in my first post a CNC would be nice but we are using it for repairing parts. such as boring pin worn 2"holes and re sleeving. and re-machining worn surfaces that have been welded up. No production parts runs. We do make replacement parts under 10 at a time but many need 4 or more setups to machine all the angled features. And they aren't going to spend alot of money on a machine. company doesn't see the machine shop as an asset. But sure want to know when we'll be done repairing or making a replacement part. I thought I explained it well in my first post as what I am looking for. the G and L we have now has a 4" 5MT spindle with a drawkey for hold milling tooling.There's one here in my town that same size. I don't think it has quite 120" cross travel, maybe 60-72" at most. Wonder if it is the same machine? Haven't been in that shop in nearly ten years. They did change names on the business.
The beauty of having a built in facing slide is you can do lots of things with what are basically lathe tools.Thanks for all the replies. Tyrone understood what I said. As I said in my first post a CNC would be nice but we are using it for repairing parts. such as boring pin worn 2"holes and re sleeving. and re-machining worn surfaces that have been welded up. No production parts runs. We do make replacement parts under 10 at a time but many need 4 or more setups to machine all the angled features. And they aren't going to spend alot of money on a machine. company doesn't see the machine shop as an asset. But sure want to know when we'll be done repairing or making a replacement part. I thought I explained it well in my first post as what I am looking for. the G and L we have now has a 4" 5MT spindle with a drawkey for hold milling tooling.
Notice
