rke[pler
- Feb 19, 2002
- Peralta, NM USA
I've got a Lagun FT-2 mill with an integral one-shot oil pump. The pump is slowly going bad. I have a replacement I found on eBay some time ago, problem is that the seal on the piston is gone. Looking for a replacement I found that the seal ID is .496"/12.6mm, seal OD is 20mm and width is .240/6.13 so I don't know if I should be looking for an inch or metric seal. The rod seal seems metric with a 8mm/14mm id/od and 4mm thickness so I expect the whole assemble should be metric, so should I be looking for a 12.5mm/20mmx6mm seal?
