bengineer08
- Jun 17, 2022
- Northern KY / Cincinnati area
Hi, I'm trying to teach myself how to program my early 90's Miyano lathe (Fanuc 0T). I'm hoping someone might have some insight into what's going on. More than likely it's a syntax error or something. Or maybe the control is older than the examples I've dug up and repurposed, and it doesn't like the order of things or something? I've got a couple quirks I can't figure out.
First, when I start the program, it'll go through the first few lines and get to the tool change line, change tool and just hang up there (no error or anything). Cycle Start won't start it going, but still no error. I can hit reset, but then it skips the line immediately following the tool change. If I hit reset, then switch to edit and back up to the line that was skipped, I can hit cycle start and it seems to run ok.
Second, I was trying to turn a fillet at the back using Z-25.0, R1.0; and it didn't seem to like that at all. If I take the ", R1.0" out it'll work just fine (but, of course, no radius). I understand there are other ways to do the fillet, but would this control be too old to do a simple "Z-25.0, R1.0;"?
N1 (ROUGH TURN);
G40;
T0101 M06; (<this is where it hangs up)
G50 S2500; (<this is the line it skips)
G96 S250 M03;
G00 X28.0 Z5.0;
G01 Z0.1 F0.1;
X-0.2 F0.05;
G00 X 28.0 Z2.0;
G71 U1.0 R1.0;
G71 P100 Q200 U0.2 W0.05 F0.2;
N100 G00 X19.0;
G01 G42 Z0.0 F0.2;
X20.0 Z-0.5;
Z-25.0, R1.0; (<-this is where if I remove the ',R1.0' it runs fine)
X26.0;
N200 G40 X28.0 Z5.0 F10.0;
M05;
G97;
M30;
Any help to tips would be greatly appreciated. Thanks.
N1 (ROUGH TURN);
G40;
G96 S250 M03;
G00 X28.0 Z5.0;
G01 Z0.1 F0.1;
X-0.2 F0.05;
G00 X 28.0 Z2.0;
G71 U1.0 R1.0;
N100 G00 X19.0;
G01 G42 Z0.0 F0.2;
X20.0 Z-0.5;
X26.0;
M05;
G97;
M30;
