Hi teemfan93:
As others have already remarked, bodging a reamer to make a flat bottom hole is a problem on several fronts.
The two main ones are:
1) If you plan to make a dead sharp corner where the wall and floor meet, you will also scarf up the sidewalls of the hole when you run the reamer down the hole as PegroProX440 points out in post #7.
2) If you don't gash the end flutes and put center cutting geometry on the business end, you won't have enough room for the chips to form...the tool will buck at the bottom of the hole and the finish will be shit.
So you need to make the end geometry sophisticated enough to get it to work.
You don't have a T&C grinder so that is out.
A flat bottom drill is the poor man's way of "solving" the problem but you still need to get the end geometry right for it to work, and the corners of the drill will dig into the sidewalls just like the butchered reamer would.
Back when I was a mold maker in the 1980's, before we had sinker EDM, we would make a "D" bit to do stuff like this.
Now you only have one flute to worry about, and you can stone a tiny (0.005"ish) radius on the corner and give it clearance only on the bottom half of the rad.
If you undersized the D bit by 0.001" or so and stoned that rad with care, you could make a beautiful hole but you had to be patient when you nibbled out the bottom of the hole and I found it worked better if you relieved the sides of your D bit, but left the first 1/2 inch or so unmolested.
Of course we had a whole range of cutter grinders to help us...things you don't have.
So can you farm this job out to a shop with a sinker?
Alternatively if you don't care about the finish in the hole, can you do as others suggest and run a flat bottom drill, even if you have to get a grind house to make you one?
The whole challenge with flat bottom drills in blind holes is to get them to center cut...if you plan to try to fake it, put a center cutting endmill on the bench beside you and try to copy the end flute geometry.
Another way you can try is to buy a 20 mm 4 flute endmill and deliberately dull the side flutes.
It might make you have to cry a bit to fuck up a brand new endmill this way, but sometimes you gotta break eggs to make an omelette.
Ream the hole with a normal 20 mm reamer first...as deep as you dare to go, then go down with your custom tool.
Cheers
Marcus
www.implant-mechanix.com
www.vancouverwireedm.com
