Machine probe options
@mr_servo
The work probe does not show a pullup resistor, that is for the tool probe. The tool probe is functioning correctly without an external resistor, so I think there is one wired internally.
Both probes are configured NPN so I would expect if one works now the other should work without requiring a parameter change, but I would love to be wrong in this instance!
When I measured the .2/5V the Signal and 0V were not connected to the machine.
I also tried connecting Signal directly to Skip (Pin 11) and bypassing the relay, this did not work either.
I will be getting in touch with the supplier of the hardware, hopefully its just user error.
