That's a real bummer. They enabled the T options on mine without question. So you can't even try hsm? What does haas corporate say about this?
I still have some cutting smooth issues, I think it is a combination of a param somewhere wrong and learning to understand min segment size depends on ipm.
I tried ethernet, but was dissapointed. I could get the control to read a network drive, but could not get the machine to show up as a network drive for my win7 machine. It's not a config issue, but rather because of a dated network stack in my opinion.
Luckily this machine was originally ordered with HSM so we turned that on. The tech was able to generate a text file of the new parameter list after we got everything correctly configured. Make sure you ask for that in your quote if you order this upgrade. It will look like the same parameter list that originally came in the binder/manual. I believe the tech can generate this file with the program he uses to create the new parameter list. I did have a Selway Application Engineer call corporate and try to enable the trial. Mama must have been on the rag and said no. The apps Engineer seemed surprised about this since the trial options I wanted were not even included in the original 13.XXX software. Make sure that you specify that you want the trail in your original quote for the Maincon upgrade and you should be covered.
This is from page 1 of the new parameter list text file the tech created on his laptop at my shop.
HAAS VF2 Parameter List S/N XXXXX 08/08/2017 Page: 1
Control software version M17.04B
Options installed:
High Speed Machining (HSM)
Brushless A Axis (fourth axis) Device
40 taper 10k spindle
LINCOLN spindle motor
Rigid tapping (R-TAP)
34-Position Coolant Spigot (P-COOL)
Coordinate Rotation & Scaling (COORD)
Macros (MACRO)
Probe Kit (requires macros) (PROMAC)
Chip Conveyor or Chip Auger (AUGER)
M19 Spindle Orientation P and R codes (S
Air Blast
VQCPS (Probing System)
NON-Smart Vector Drive-no holes on cntl
BIJUR oil system (TYPE 1)
DTE25 oil
YASKAWA SGMG-1 MOTOR
High intensity light (HIL)
X NON-SMART AMPLIFIER
Y NON-SMART AMPLIFIER
Z NON-SMART AMPLIFIER
A NON-SMART AMPLIFIER
Code to turn on ENABLE MACRO: ______
Code to turn on ENA ROT & SC: ______
Code to turn on RIGID TAP: ______
Code to turn on M19 SPND ORT: ______
Code to turn on HIGH SPEED: ______
Code to turn on FOURTH AXIS: ______
