make a bushing
ben80
Aug 22, 2007
michigan
I have to make up a couple of bushings for a lawn roller, I want brass or some metal that will wear and not wear the steel down. I plan to put fittings in it and grease it often.
I did some looking into this and they said SAE 660 Bronze would be good. I would like it to last some time with lots of grease and not not damage the steal.
Another said that Oil-lite brass or bronze would be good for this?
Thanks for any ideas on this.
ben 80
ben80
Aug 22, 2007
michigan
I will go to the local , metal shop and see what they have. I don't mind the machining part, will have to do some. It always comes to this, ya buy cheap, ya get cheap. But I can fix it.
thanks
Punkinhead
Feb 13, 2010
IN, USA
I'd be surprised if you can't buy what you want from McMaster Carr. The only bronze bushing I've ever had to make is one for a WWII era airplane that called for a special alloy. The size was readily available for a few dollars from McMaster and probably would have outlasted the plane, but when working on aircraft you don't make material substitutions. For a lawn roller? No way I'd waste time making something I can buy with the loose change in my pocket.
ben80
Aug 22, 2007
michigan
I am a retired machines of 40 years, making auto parts and set up a hobby machine shop in the basement. Its a full shop, I was making so much money with OT I could afford it.
Keeps me tied to my roots and helps me with hobby’s , etc. Don’t mind fixing my blunder ,buying metal to fix this. LOL
I am going to McMaster Carr and ordering the metal.
Thanks for all the info, you guys are great.
ben
ben80
Aug 22, 2007
michigan
I forgot to ment6ion, its a 900 lb roller, I do part time mowing, etc and rolling helps me get the jobs done quicker.
I ordered the SAE 660 from McMaster Carr, price was not too bad and it won’t take much to finish. I got it with the 1 in. bore, no drilling.
Thanks again
ben
gbent
Mar 14, 2005
Kansas
While it seems a little backward, the bearings are to support the pull frame, not the roller. Not much actual load.
ben80
Aug 22, 2007
michigan
These are to bearing to pull the load. The draw bars go on them. I would guess a reg. load of 450lb. each , with max up to 600 to maybe 800 lb. when loading etc.
The rods that the bearing go on , is hollow tub steel. I am going to have to put a solid steel rod thru it.
Not sure what kind of steel would best, any idea's???
ben
DDoug
Oct 18, 2005
NW Pa
I've seen everything from simple steel pipe bearings with maybe a grease zerk, all the way
up to brake disc rotors and axles on these things.
It this for commercial, landscaper usage ? or "Once every springtime" ?
Rob F.
Aug 5, 2012
California, Central Coast
Use 1" cold roll bar, it should work as is in the 1" bore of your bronze. Just a slight polish, if anything to make it a really nice fit.
Any steel you have on hand would also work.
ben80
Aug 22, 2007
michigan
ya, its commercial, but just part time, a little extra money and it will help with my mowing ( faster mowing more profit).
I will put the cold roll steel , down the center. The brass bearings and the steel in the hollow steel , should make it last a little longer.
Thanks for all the help
ben80
mark costello
Jun 25, 2001
lancaster,ohio.43130
Not that I am too anal about things, I use a 48" deck on a riding mower and got tired of rebuilding the shaft and rollers. So this winter I rebuilt the shaft with a piece of 4140 PH. The rollers were made out of UHMW. I made a clamp that tightens with a bolt so that just unloosen the bolt and it all slides off. We will see who wins this round.
DDoug
Oct 18, 2005
NW Pa
Is there a chance that the steel shaft is rusting in the off season ?
