smartcolombyan
- Dec 24, 2020
Running lights out, trying to make things last as long as possible and I hate running back to fill up the lube tank especially with a dumb funnel into a small container that wasn't built right. I wanted to create a custom plexiglass box which just sticks out a bit to allow for a better entry port. I think as long as the fluid depth height doesn't change it shouldn't mess with the gravity head load for the bijur pump. At that point I might be tempted to have a secondary float valve pump to autofill it from a larger way oil container being gravity fed from a 5 gallon bucket for example.
